General drivers side airbag removal
gstar1
hi does any body no how to remove the drivers side airbag its doing my head in now. carn't see any thing or feel if there is any bolts or hex in there any help would be much appreciated
Mayatt
White Grande Sporting
Home
disconnect the battery leave to discharge all power in them for about half an hour had no problem whacking them about after that before, why you need to remove it? gunna have a big ol warning light on your dash if you do
beany_bot
Stuff Your Own Title
SCOTCH-LAND
Ok ill ask the obvious question then. WHY? and WHY is it "doing your head in" cant say mines been too much trouble where it is. lol
OP
OP
G
gstar1
yes i no that little bit but what i need to no is the airbag held in place with tork bit (what size) is it a nut (what size) or is it by a clip or something totally different. plus you cant see a thing
OP
OP
G
gstar1
if you read the post RE (drivers side airbag removal)
it is doing my head in because i can not remove it i can not see what is holding it in place if i new what was holding it in place it would help me a lot so if any body no what is holding it in place let me no
Mayatt
Home
still not really said why? "its doing your head in" is pretty lame reason to be taking an airbag out? still cant grasp what the necesity is to get rid?
OP
OP
G
gstar1
both air bags has been deployed my mechanic is trying to save me some money on labour cost by me removing the dash and airbags if i break it so what there is a new one going in as for me telling you the reason is neither here nor there what help would that give other people looking through posts for information on how to remove the airbag. this was a genuine post so if you don't know how to remove the airbag don't waste the post for future reference with pointless post like (still not really said why? "its doing your head in" is pretty lame reason to be taking an airbag out? still cant grasp what the necessity is to get rid)
OP
OP
G
gstar1
Just looked at my manual. Remove the glovebox and there are 2 electrical connections 1 each end, 2 retainers which look like they are at the back and a single bolt at the bottom center facing you :) HANDLE WITH CARE, STORE WITH BAG FACING UPWARDS AND AFTER REFITTING SYSTEM WILL NEED CHECKING WITH EXAMINER FOR ANY ERRORS.
sounds promising what page is that on. thanks for the help
marty61
He Who Dares Wins
Reading
My manual is on cd-rom, there isn't one in print yet.
INFO I GAVE WAS FOR PASSENGER SIDE SORRY, I WILL LOOK UP CORRECT PROCEDURE FOR DRIVERS
marty61
He Who Dares Wins
Reading
There are 2 special tools that have to be inserted into the holes in the side of the steering wheel to release the airbag from the wheel. They look like a rod with a ball on the end.
OP
OP
G
gstar1
thanks marty will check that out today cheers
Mayatt
Home
if you check on ePER the diagrams would give you a good clue to where the screws and rivets are hth
OP
OP
G
gstar1
yep thats how its done you need to pierce two holes on the side off the steering wheel with star headed screw driver then push the screw driver in and up the air bag just pops out or you can get the proper tool from fiat but screw driver does the job cherers marty
OP
OP
G
gstar1
If the airbags were deployed the airbag ECU would need replaced & therefore configured by dealer.
you can get the module reprogrammed but i bought a full kit seat belts air bag module ,dash board, passenger air bag and drivers airbag
