- Joined
- Sep 14, 2009
- Messages
- 19,972
- Points
- 3,976
I could not get my shaft out of the gearbox. The retainer is just a wire snap ring, but unless you can get a direct push it's never going to shift. Looking at the scars on eBay's used drive shafts I'm not the only one having trouble.
One option is a special plate and slide hammer but I dont have a slide hammer.
But I do have a fork type ball joint separator that I dont use. They are cheap enough anyway. The tapered forks need to 55mm apart and the ball joint tool is just 19mm.
A good hefty angle grinder with slitting discs did the job. They self destruct without constant pressure and self destruct with too much pressure and as the slot gets deeper they (erm) self destruct. But I got there with a neat enough cut.
The 50mm x 5mm steel strip was easier to cut. I made a jig with some plywood and tacked in the steel separator plate. When happy welded it up properly. The welder was running from an extension cable so the welds are rough, but it's good enough and had the shaft off the car with two taps from the lump hammer. I need to make up a heavy duty extension cable.
