Technical Drive-shaft coupling 'boots'
the hobbler
Distinguished member
Peter, some time ago you mentioned that you had put some big rubber 'boots' on your drive-shafts to prevent 'muck 'n bullets' getting onto the drive-shaft/ coupling splines. (a) has it proved successful, (b) where did you get them from and, (c) what size boots did you get? I will be putting new drive-shaft bearings on my Fiat when it comes back from the body-shop and, subject to your observations, thought this might be worthwhile doing at the same time.
My experiment was bit of a fail Tom.
I got the boot from MisterAuto as an add-on when I was ordering in any case for my modern; it was listed as suitable for the Fiat 500.
http://www.mister-auto.co.uk/en/joi...k-bol-17086100e_g90271_a999BOL-17086100E.html
But because the outer needs to be fitted to the aluminium coupling or driveshaft flange this means there is no clearance because of the tight fit in the swinging-arm.
I trimmed the rubber down and made it fit. it hasn't moved or cracked or leaked any of the extra grease I slapped in. But it's not the professional job I hoped it would be; I may revisit the idea in the future.
Thank you for your reply and observations Peter---much appreciated. It is this ready exchange of information that makes this forum one of the best---informative and interesting--and occasionally educational!
I have to replace the driveshaft boots for the third time - and haven't even driven it!
