G gabygraef New member Joined Dec 15, 2012 Messages 26 Points 13 Dec 1, 2014 #1 hi, do you have any ideea on the 1.9 jtd how to drain the entire cooling system? from the engine block ?? thank you
Raziel New member Joined Nov 26, 2013 Messages 5 Points 1 Dec 10, 2014 #2 Per service manual, draining is done by the small plug on the bottom of the radiator. It seems to be the lowest point of the system.
Peter Pick-Up Patron member Parked in the garage Joined Mar 15, 2008 Messages 5,118 Points 1,123 Location Netherlands Dec 12, 2014 #3 Open the heater controls inside the car. Unbolt the lower radiator hose, open the expansion bottle, and wait some minutes to get the coolant out, done.
N Neverth Established member Joined Jan 18, 2012 Messages 665 Points 201 Dec 13, 2014 #4 Mine had drainplug in the bottom of radiator (changed cambelt today). As for opening heater controls, no need as there are no valves in the system. Only air is routed to/bypassing the heater matrix.
