Technical  drain cooling system
gabygraef
hi,
do you have any ideea on the 1.9 jtd how to drain the entire cooling system?
from the engine block ??
thank you
Per service manual, draining is done by the small plug on the bottom of the radiator.
It seems to be the lowest point of the system.
Mine had drainplug in the bottom of radiator (changed cambelt today).
As for opening heater controls, no need as there are no valves in the system. Only air is routed to/bypassing the heater matrix.
