Technical Double DIN radio mount for Ducato 2004 based Motorhome
benbgg
I'm trying to convert the single DIN radio mount on my Hymer B584 motorhome to double DIN. On another forum, I've seen that that part number 735305823 is what I need.
I can see it on your site. I have two questions:
1) I can't seem to place an order on eper.fiatforum.com site. I can only see "Print order" and when I click on that link it's unreadable.
2) Is that all I need to do this conversion?
Thanks in advance,
benbgg
Bring the part number to dealer, its half the price from citroen though. I think the citroen part number is:8226 05 its £46 versus £97 from fiat. You can also order with the fiat number via Iveco dealer.
Sorry, I kind of figured that a bit after posting...
Seems quite short for a part number - Is there any prefix?
Citroen / PSA part numbers are alphanumeric so much shorter you can register yourself at service.Citroen.com and check.
Thanks for that - tried registering but seems to be saying only trade customers, come back later and they'll have a service for individuals..
Hello again. I finally get hold of the Fiat Part for this project - but I'm still not there. THe resulting hole is too wide for a double din mount - except between 2 screw holes. I'm guessing this is to accomodate another part number - 1340009080 which provides a mount into which you can put the head unit.
I'm attaching an image (if I've understood how to do it properly)
Has anyone actually used this part and could they confirm that that's the one?
Thanks in advance.
Yeah mate,theres a metal cage that the headunit slides into,'im about to whip mine out so ill send you a picture.....I'm trying to fit a connect nav+ with reversing cam from an 03 ducato to my 03 relay its doing my head in.i saw a ducato in the scrappie with the whole system in In my haste I took the headunit and camera thinking it would just connect upbut I'm having real difficulty suessing it. Ive since been back to scrappie got mic's aeriels wires etc but i think im missing a few bits
No wiring diagrams to be found,closest I can find is a stilo version and half the pinout say n/c if it's n/c why do I have wires coming from them on the 18pin connector where do they connect..???? and is the coaxial on that connector The camera picture cable?????hu
any assistance would be hgreatly appreciated......
Check this out
Hi, thanks for the pics.
Only just got this picture - I was on a long trip with virtually no internet :=(
I'm afraid I haven't found anything for the Fiat Double DIN unit - I'm trying to get a third Party one installed...
Just got back after a long trip and looking at this issue again.
You wouldn't have the Citroen p/n for 1340009080, ( the metal cage that fits inside the Fiat Double DIN facia) woul you?
Thanks in advance
I have just come across this post as I am also looking to see if I can upgrade my dash to a double din as you are doing.
Have you managed to get yours sorted out? Can you let us know how far you have progressed?
regards,
Hi, I have here is how it happened, but had to make an additional frame.
also connect reversing camera in mediaplayer there is a possibility
You have made a nice job of that 24Rus.
Trying to find the enclosure at the right price at the moment. Fiat dealer wants £130+ for one. I have found a supplier in spain a lot cheaper but will not ship to UK.
need to upgrade my radio on a 2004 motorhome
looking for double din upgrade parts for the dashboard.
want sat nav, dab radio?,rear view camera
anybody help with part numbers and some pics.
Andy j
Hi Andy, anyone
Did you get sorted with one of these adaptors ? If so do you have details of parts and any issues please as going to do the same to a 2003 camper!
cheers
Ian P.
New to the forum and I know I'm resurrecting on old thread but I'm sure like myself many came across this in the search for a solution to getting a double DIN installed in a pre 2006 Ducato and so this will be a help to others in the future hopefully. The original OE bigger housing thats mentioned at the start is no longer available unless you can find a used one but TBH its not a perfect fix as it has a rib around the front that makes it look a little unfinished when you make a double DIN fascia plate to fit inside it. My solution was to use the original single DIN parts and modify to suit. I will add more pics in the coming days as I'm just assembling it all now but everything is done and it will work. The picture shows it unfinished but it gives you an idea of what it will look like and the nice thing is its very cheap to do if you're handy. (edited to say I'm just trying to work out how to add pictures)
New to the forum and I know I'm resurrecting on old thread but I'm sure like myself many came across this in the search for a solution to getting a double DIN installed in a pre 2006 Ducato and so this will be a help to others in the future hopefully. The original housing thats mentioned at the start is no longer available unless you can find a used one but TBH its not a perfect fix as it has a rib around the front that makes it look a little unfinished when you make a double DIN fascia plate to fit inside it. My solution was to use the original single DIN parts and modify to suit. I will add better pics in the coming days as I'm just assembling it all now but everything is done and it will work.
