Technical Double DIN radio mount for Ducato 2004 based Motorhome
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
New to the forum and I know I'm resurrecting on old thread but I'm sure like myself many came across this in the search for a solution to getting a double DIN installed in a pre 2006 Ducato and so this will be a help to others in the future hopefully. The original housing thats mentioned at the start is no longer available unless you can find a used one but TBH its not a perfect fix as it has a rib around the front that makes it look a little unfinished when you make a double DIN fascia plate to fit inside it. My solution was to use the original single DIN parts and modify to suit. I will add better pics in the coming days as I'm just assembling it all now but everything is done and it will work.
Did you manage to complete this and do you have any pictures and details on what you did?
I've just purchased one of these and it's looking really good with my new double din.
Looks really good.
What Joying unit did you install?
How easy was the frame & joying to install?
I have a Ducato 2.8jtd 2003 and would love to instal what you show in your pic.
Looks really good.
It was the Joying 7" Android 10 Double Din unit. Bought it direct from Joying and seems like a great unit. Took about 2 weeks to arrive from China. It fits perfectly in the mount and the mount I got from eBay was quick and easy to install. Easy job. Hardest part for me was working out the previous owner had moved two pins around on the vehicle iso lead. Pretty much plug and play after that.
mfuller,
Did you get your 2din mount via ebay from Italy?
If so how much extra import duty did it cost?
That looks good but there's no way I'm paying £140+ for a piece of moulded plastic that probably cost £10 to produce. Surely there must be a market for someone with a 3D printer to run these off and sell them for £30 or so?
Did Martinb624 ever reply?
Does anybody have anything to add to this thread regarding where to source these 2 din mounts for the 1996-2006 Ducato, Relay and Boxers?
:cool:
