christopher watson said:
i think my horn has gone the same way as yours, as i pressed the steering wheel centre, and nothing has happened (any help please).
The most common failure is the horn, which is behind the bumper.
UK passenger side.
To get at it you have to remove the wheel arch liner (3 or 4 self tapping screws), then unbolt the bumper bracket and side support on that side only.
Being fuel injected you'll also have the carbon filter in the way down there, tangled up with the bumper bracket mounting nuts.
Basic operation is volts to the horn, and earthing via the steering wheel push button, so you need one with two connectors from the scrapyard.
But before you go there -
When you get access to the horn you can find out if the problem is the horn, or a wiring issue, by checking the voltage on the black lead when the push is pressed - there should be a voltage until you try to operate the horn.
There can be some issues with the earthing from the horn:
There is a a brass ring under back of the steering wheel which provides continuity regardless of wheel position, it wears out.
Also there is an earth through the body of the steering lock/ ignition switch area somewhere, which also becomes intermittant. It will commonly work "straight ahead", but not with some lock on.
The two wires at the horn unplug (when you can get at it) and will pull back below the headlight so the connectors are always accessible.
One is grey/black the other voilet.
The violet one is +12 straight from fuse 3.
The grey/black finds an earth via the horn push etc., as mentioned above.
