trisha1963
- Joined
- Jun 12, 2013
- Messages
- 1
- Points
- 1
Hi Newbie here, Trisha is the name,
Ok right down to business, I have a Fiat Stilo 3 door 02 reg 1.6 Active, Nice car however, I have a problem Running on 3 cylinders, Yep you probably fed up of this one , I have had it checked and coil pack 4 was down, so nice new coil pack installed and eek no change, It appears not to be getting power up to the coil pack , I am a PC technician so was able to do a check on multi meter,
I read somewhere that if a coil pack fails this can cause the same channel on the ECU to fail also.
i do not know much of cars but well money is tight with me as well and I would rather try and fix it my self if it is possible, as the cost of even just looking at it is way to much .
Is anybody out there came across thiss issue before and can anybody help me out here
