General Does anyone installed original subwoofer in Stilo?
RainMan1
Bucharest
Hello.
I want to buy Stilo's original sound system with 8 speakers and a subwoofer. Anyone retro-fitted one? I am not sure about wiring, cause i want to get everything i need. Elearn gave me everything, but i am not sure what "HI system junction" is and it look like.
Unfortunately it's not as easy as just installing speakers. The sub woofer has a built in amplifier which also powers the inside speakers too so there's a lot of wiring involved. The amplifier has to be wired up to the head unit and then wired to the other 7 speakers. However your model of car may have the wiring loom already installed. If you have alook inside the boot on the left hand side behind the carpet and look for a black and purple connector?
I don't have it. I installed electric/heated seats so i have the rear fuse panel there, also fitted by me.
I don't know if there is another conector, or fuse box, or something between amplifier and radio. According to elearn, is something there, and i am not sure if it's another part of the sound system or just a conector :-??
I am confused about the conector situated in the left side, near driver front door conector.(left hand drive).
I attached a picture in the 1st post, from elearn. Something is there and i don't know what it is
The other part of the Hi-Fi wiring diagram shows where D68B and D68C are in the circuit.
D68A and D68B are similar 10 pin connectors. D68A connects the outputs from the radio to the inputs of the amplifier. D68B connects the outputs from the amplifier to the speakers.
D68C is a 2 pin connector at rear fuse box to get power and earth to the amplifier.
I installed in mine. The big question is to get the amplifier and the cable. I have to sell one subwoofer but I don't have the cable and the rear fuse box. I get in scrap yard but is not easy. The cable is big. And if you want to install a aftermarket radio you need to add a extra cable to turn off/on the sub, nothing special is easy to do.
