Technical Doblo rear door mechanism
Ok the latch when I lift up the bonnet is new one on the door itself As I thought it was that the lock. But it would make sense it's not connecting to the receiver. But solid no cables. So I don't know if it's possible. The handle off the door I'm guessing key won't turn it for some reason on the outside of the car would that be an issue
does the rear LOCK turn through 90 degrees..??
Sorry please explain. You mean the key inside the lock turn no the key won't turn it. Don't know why the lock itself I don't know to be honest. I tried to use a pen to simaalte the door closed and that didn't let me see anything. But the catch does close to hold the boot closed so you have to life the handle to open
The key will not turn in the rear. Tried to fit the key and it's like the jet isn't meant for the lock.
Sorry using one made up suffer from dilixa. Reading writing unstanding is lacking.
