Technical doblo maxi sx rear door cover
You're not the only one waiting for a reply...
I've got a door handle that isn't working. I have to use a key in the lock. Fortunately that works.
Are you thinking of the internal panel? Which is almost certainly a case of ripping the plastic pins out. It's worth getting a bag of replacement ones off of Ebay (other respectable sources are available)
Now the big section on the external, lower part of the door, which houses the handle and number plate, that is a bit trickier. I would also appreciate info on that.
Thanks varesecrazy
Excellent advice about looking at Fiatsdaly. It took a bit of searching but it was there.
Funny thing though. for the moment the lock has started working again. No, I have absolutely no idea why.
I will update if I have any other issues.
