Technical Rattling front door (Doblo Cargo Maxi 2019)
xszaszax
Hungary
I bought a 2019 Doblo Cargo Maxi. The right passenger door is rattling over bumps. Wife tried to push on the door from the inside while going over bumps. This seemed to make it better. Any ideas how to fix?
Thanks!
Thanks!
Is it the hinge end or the lock end?
If lock end has the plastic on the actual catch worn off and also is it possible to adjust the part in the door frame that the door lock engages in, usually it can be slackened a little and moved in slightly to tighten the door closer to the car body.
Always assuming it isn't something like the window channel lower mounting bracket bolts in the door, does it sound different with window down.
Hi! Will check and reply! Thanks for the suggestions!
