Do anybody know the ET of the Wheels ?
C
Cedric
I've got a bravo hgt from 1997 with 205/50/15 original wheels do you know the ET of the Wheels ? that would help me.
ced from France
Is ET the same as offset?
If not what is the offset? Alfa wheels have 98mm pcd.
Fiat PCD
Tom,
What is a PCD of a Fiat Brava 1.8ELX year 1996. Because I have installed a 100 PCD sport rims that suited especially for Honda Civics. But sometimes, when unbolting the wheel, the nut broke. Some say the PCD is different. But do you think a 98 PCD can fit a 100 PCD wheels, or simply Fiat wheel nuts tends to break at a certain age? Please advise.
Regards,
SYED.
Wheels PCD
Hi Syed,
AFAIK Usually the 100 PCD wheels would not fit a 98 PCD. So what these people do is they drill the hole bigger (PCD 100) but at the end of the day u probably will screw your ride and hence the broken screws.
You can fit 100pcd wheels but...
you end up with 'wobbley wheel nuts'. The wheels in-effect are on loose, you can't fit locking wheel nut though is the only down side!! Can be done a mate of mine put 18's on his punto with 100pcd. I wouldn't like to do it myself though.
2
770
Sabre 23
S
C
653
ChrisKnottIns
C
M
521
M
