Apologies
I may have misread your post and then posted it wrong myself, for some reason confusing the GSR induction kit with a DV kit
(It's not my fault, their website is awful
) However I wrote this massive reply and I am really pleased with it so I am going to post it anyway.
A DV cannot increase performance. There is nothing for it to do other than go PSCHTTTTTTTT and unless it's perfectly actuated and it gets it spot on it will loose you boost pressure.
The boost pressure is generally highest on a diesel when the accelerator is on the floor and the engine is as max power, just before a gear change. If a dump valve is set to relieve the pressure just below max boost, it will sound similar to that on a petrol engine, but it will be dumping air while the engine is on power, not when the accelerator has just been released. All it can do is make the turbo less efficient. The wastegate tries to control the boost pressure and that will just increase the exhaust back pressure if the pressure is being dumped by a dump valve.
Now also figure in the fact the fact the JTD turbo is a VNT (GT1749V I belive if it's the 85bhp version) and this works works by adjusting the gas throat section at the inlet of the turbine wheel in order to optimize turbine power with the required flow velocity. At low engine speed and small gas flow, the turbocharger reduces the throat section, increasing turbine power and boost pressure. At full engine speed and high gas flow, the VNT increases the throat section, avoiding turbocharger overspeed and maintaining the booster pressure required by the engine.
How do you think sticking a remote control hole (Which is what the valve is really) in the system will effect this? It will defeat the object totally and all it will do is work against it.
I would really like to see a dyno run of a standard car and the one fitted with a DV back to back. I think the run with the valve would show early boost loss and spikes where the VNT is struggling to compensate. The only way it could be perceived to increase performance is if you mapped around it which is pointless because you might as well have just mapped a standard engine
It's an expensive toy and about as useful as a catflap in a submarine.
