MountainRunner
- Joined
- Aug 7, 2014
- Messages
- 88
- Points
- 95
Hi
As you know the Panda multijet has a spring like flexible dip stick. However when I check the oil level I remove it and wipe it as you should then re-insert it before removing it again to read it, however the bottom few inches is always smeared with oil, meaning I don't actually know how much oil I have.
(I always check oil level as normal, on the flat without recently running the engine)
This is of particular concern as I have a small oil leak from the cam chain case and with the smearing on the dip stick, it could look like I've more oil than I really have. I've not added any oil since about April and surely the oil level must have gone down since then.
I don't want to risk adding extra oil as it could damage the engine and ruin the catalytic converter.
Is there any certain way of checking the oil on the Panda Multijet?
