I'm searching for a replacement gearbox for my Punto and have found a few on the internet. Adverts usually state the specification of the gearbox and the car that it came from. I have found that some sellers have a "Check if it is compatible with your car" selector. When I have used the selector at times it has come up with a negative for a gearbox advertised as the same as my faulty one.
So hence to my post. I got to thinking, is this about the gear ratios in the gearbox? A diesel engine has a different power curve to a petrol one so you would expect the designer to take this into account when calculating the gear ratios in the gearbox? A so-called sports version of the car might be expected to have ratios that give better acceleration but it might not perform so well when loaded to the gunnels with building materials.
So my questions are:
I have a:
Fiat Punto Grande;
1.4L (1,368cc);
8 valve;
77BHP;
Petrol;
Nov 2009 reg.
Any thoughts or information would be helpful.
- Do gearboxes from the same model have different gear ratio variants?
- If yes, then does it make a significant difference when buying a replacement?
- Have I got this wrong and are there other factors to be considered?
I have a:
Fiat Punto Grande;
1.4L (1,368cc);
8 valve;
77BHP;
Petrol;
Nov 2009 reg.
