Knottyham New member Joined Jul 23, 2013 Messages 22 Points 10 Mar 19, 2014 #1 I'm wondering if it is possible to remove the twinair badge from the back of our punto. If so is it likely to damage paint? Also if we were to do it, would insurance need to know? Thankyou.
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,811 Points 8,382 Location Near the M4 Mar 19, 2014 #2 Knottyham said: I'm wondering if it is possible to remove the twinair badge from the back of our punto. If so is it likely to damage paint? Also if we were to do it, would insurance need to know? Thankyou. Click to expand... interesting question.., I suspect it's just held on with a sticky goo.. so warming thoroughly should let you carefully peel it off, ask in the GP section..as sombody will have debadged the same tailgate.. charlie
Mkala Established member Parked in the garage Joined May 10, 2012 Messages 724 Points 204 Mar 19, 2014 #3 Normally just warm it a carefully remove it... If it is not too old, you will not have paint difference. Use hairdryer to warm the part; with a heat gun you have to be careful or set it at low temp, or you will toast your paint.
