Styling debadging a mk1 punto
Don87
debadging a mk1 punto, what has to be done? is it very easy to do, any painting or filling required?
Bonnet badge leaves holes
Rear tailgate leaves holes
Badges above side repeaters are just glued on can be taken of easily
So yes filling, welding & painting will be involved.
I just colour coded my badges... too much effort taking them off
On my mates punto mk1 we just took of the rear badges with some hot water and a spoon. We then covered the holes with filler & sanded it down till everything was flush. On the front badge we took it off, and filled the indent and again just sanded down till it was flush. Then went to Halfords, got some paint mixed up, and now looks as good as new:D
What would need welding?
Dont bother de-badging!,
everyones at it!!!
what you wanna do is just upgrade to some new shiney mk2 ones!!!
like this!!
no filling,or welding,and i think its quite neat!
lol
i woudlnt bother welding a plate behind either, get a 5p peice and bond it to the back with something hardcore, that will cover the hole and it will be very strong.. then fill it and spray it :)
job done, easy as that
That's how I was considering going about it.
Epoxy on some pennies from the inside, fill, sand, paint. Ideally mask the bonnet where a badge wouldn't cover, so if it really does look pants you can whack a badge back on as a quick cover up :)
Was getting ridiculous quotes for filling and respraying, and it's not worth it in my opinion!
Tin of paint would come in handy for some colour coding too while I'm at it...
Oh well, maybe when the temperature's back in positive degrees celsius eh?
Like someone said, just unscrew and pull off the plastic bit from the boot lid, and take off the badges by heating them up and use something thin to lever them off(i used an old solo card:p )
Then find the appropriate holes from inside the boot and araldite some pennys onto the inside side of the holes.
Then put masking tape over the holes cutting out where the holes are, this way you dont get body filler on your paintwork.
then sand down so it is flush and touch it up with some paint.
did it to mine and looked good as new, (pointless as i bought a hole new smoothed boot soon after:D :D :D )
hope that helps(y)
Araldite and pennies is a good idea. Alternatively, apply some of the glass-fibre body repair stuff over the back of the hole, then fill, sand, paint. (y)
If you have some lying around then yeh, that probably is the best way but only if you know how to mix the resin and hardner to the right proportion and have the smallest brush in the world to apply it into the small entrance to the back of the boot, oh and also avoid dropping it onto any of the car as fiberglass resin is nasty stuff when you drop it on things. And not forgetting stinking out the whole car for about a month:D
