Malnisbett
- Joined
- Jun 19, 2021
- Messages
- 11
- Points
- 55
Hi, Hope someone can help with this.
Got a 500l dualogic that is stuck in neutral (even though the dash was saying reverse and reverse light is stuck on constantly)
When it arrived the brake switch was hanging under the pedals so I assume someone has already investigated an issue with it.
Fitted a brand new brake light switch today and since then the instrument cluster has died and brake lights do illuminate at all.
The cluster lights up when you unlock the car and then shows the fiat welcome screen then goes off totally.
Checked for codes on the Autel machine and it's all clear??? I'm thinking the brake light switch must be blowing something but all fuses look good? Thanks in advance
