De-cat pipe
De-cat pipe
G
Gav
I am looking at getting a de-cat pipe for my HLX however so far I have only seen them advertised for the HGT. Is anyone aware of one for the HLX ?
Also, I believe that of few of you have de-cat pipes so would be greatful if you could share you experiences with me regarding them, ie power gains, volume gains !, good/bad experiences with different companies, etc ?
Cheers all
Gav
i have a powerflow de-cat, cost me £40 it dosent really add volume but i think it makes the exhaust sound much nicer a bit more boom and pop rather than splutter and fart!!!
as for power gain i have no idea!
Re: Re: De-cat pipe
£40 ?
did you have to supply the flanges from the cat at that or what ?
I spoke to powerflow when I had my exhaust done and he quoted me about £45 for a pipe and £95 for a box, the pipe being a bit louder, however he said he would need the flanges from an old cat as well ?
Also, on another note. Does anyone know what diameter the pipe is at the airbox ?
I am thinking of adding an induction kit but mounting it away from the engine heat and then running a pipe from it and wondered what diameter pipe I would need.
Thanks again
Gav
Re: Re: Re: De-cat pipe
If its a 1.8 hlx, the diameter of the throttle body is 82mm, the pipe goes smaller though into 76mm at the airbox. I have a 82mm pipercross viper in the wheel arch, with a pipe connecting it. it works well and gives excellent torque gains.
Re: Re: Re: Re: De-cat pipe
Chris - so is the pipe you have 76mm then or 82mm ?
Rob - which powerflow centre did you go to for that ?
Re: Re: Re: Re: Re: De-cat pipe
i went to a place called stafford tyres which is near stoke on trent, i highly recomend them and even persuaded amit to travel up from london to use them!
if you want their number ill dig it out for you!
cost me £260 for the de-cat pipe and a cat back exhaust and the whole thing is gaurenteed for life :eek:]
1
372
S
6
249
Sly Si
S
N
3
438
B
M
26
442
colin
C
