Interesting thread, but I didn't think my 500 had DRLs!
When I turn on the ignition, no headlights come on.
Twisting the light switch to '1' (it only has positions 0 and 1) turns on dipped beam headlights and parking lights in the lower light units.
Moving the stalk engages high beam (the lower light units become bright)
Turning the ignition off turns all lights off.
It took me a while to figure out that twisting the light switch off, then on again, with the ignition off, puts on the parking lights. Therefore it isn't possible to drive with only parking lights on, which is a little annoying as it means it also isn't possible to turn on the fog lights without the dipped beam headlights being on. The whole idea of a front fog light is to cast a lower and less distracting beam than a standard headlight. I think the 500 front foglights are more a decorative item than anything else!
I had read the handbook but it didn't seem to make the lighting operation clear at all
Well blow me down, I went outside and looked and saw a dual-filament bulb in those lower light units. I thought therefore that there must be a menu option to turn them on, but hadn't seen it in the usual menus. I tried pressing MENU/ESC a number of times but it would just beep as it usually does, no menu appeared. Then I turned off the stereo and voila, a menu appeared that I had never seen before, with all sorts of exciting things. I found Day lights in the menu and turned them on. Problem solved... and hopefully a bit of practical advice there for anyone else wondering if they have DRLs (which stands for Daytime Running Lights). Or for anyone with the early Blue&Me system wondering why they only have half the menus.
In NZ there are billboards that tell us helpfully that "Winter's here - slow down" and also to turn our headlights on even during the day. When travelling out of town, I usually do. Maybe now I won't.
Now I'll be able to confuse the Warrant of Fitness testing station with the DRLs being on... they probably won't know what they are and will probably instruct me to turn them off, as they have no warning light on the instrument panel and therefore technically aren't allowed under the NZ rules for headlights.
-Alex
-Alex
