Dash Lights
Dash Lights
T
Tibbsy
Hi yet another quirk in my Billy Bravo, the light behind the rev counter seems to have blown? half the reve counter doesn't light up at night. Is it a big job to get at it and replace it cos it's melting my brain at the moment!
bulb replacement
To get the instrument panel out you have to remove first the steering column lower shroud, then the upper shroud, followed by the fuse box cover. This gives access to the screws securing the instrument panel surround which has three upper and two lower screws and also connectors to the rheostats. Once this is done the four instrument cluster screws can be removed and the plugs disconnected and it should then be out. Just change the bulb and put it all back together. Easy!
J
730
J
S
2
587
Dark Lurker
P
2
489
Dark Lurker
J
1
306
M
