General dash lights...
andy ilsf
s.wales
all my dash lights are working bar the heater and air con dials it's bad at nite when you cannot see the dials is this an easy fix or does it mean taking the whole dash apart..
Hi Andy
I had a similar problem but it was my cigarette lighter aswell as a couple of dashh lights that had packed up.I checked all my fuses and all were fine.Then i noticed there were more fuses that were behind whats looks like plastic mesh.Had a check of all fuses in there aswell and found one 30amp fuse had blown.Changed it and halleigh luiya :worship: my dash lit up like blackpool illuminations.(y):D
It is probably a different prob to what mines was but worth a try.
Kev
Hi Andy
Kev
hi m8 my ciglighter is fine it's only the 3 round dials above that are not working making me thinks it's not the fuse tho i hope/wish it is....and if it's a dash out fix is it a lot of work ..thanks 4 your reply by the way...
Hi Andy
They are the same dashlights that went on mine.Thats what made me think it could be the same problem apart from the cig lighter.
Good luck anyway.
Kev
Hi Andy
Good luck anyway.
Kev
hi kev m8 well i'm glad of that all i need to do now is findout where that 30amp fuse is?info lads if anyone can help andy..
The fuse that blew on mine was in the fuse compartment near the top.Just remove your fuse cover on the cosole to the right of you steering column look into the fuse compartment . there are a load of fuses that are covered with a black plastic mesh.just pull the mesh away and check all fuses.Like i say it might not be the cause but it was on mine.
Kev
