dash instrument problem
M
Mike
HELP!!
Had a rear box fitted today, welded on but now there's a dashboard problem.
The speedo, mileometer, rev counter, fuel and temp gauges dont work!
Any suggestions of whats wrong?
Thanks, Mike
Checked the fuses ?
Members Site - - - - - - - My Site
Yeah, fuses seem ok and the other things that work from the same fuses work too ie 3rd brake light and cd/radio etc.
who did the welding. did they dis connect the negative of the battery?
Dont know if the battery was disconnected, hopefully it was but unsure, cant go and see him until friday, unless i'm on standby in Lowestoft over the next couple of days.
Take out the dash and check the connectors on it - there is a guide in the repair section.
If that dont work - check the fuses under the bonnet and ununder the glove compartement
havent checked fuses under the bonnet, will give that a go. It is hopefully fuse related. Maybe just a coincidence of the dash not working and the rear box instal.
Seems strange that the other items working from the same fuses work fine, hints that its not fuse, will check them all to be sure.
OK, checked each fuse by pulling it and checking, putting it back. No fuses blown. Tried ignition and everything works! It could only happen to a Fiat.
Thanks for your input.
Mike
W
922
wakka
W
T
1
803
Joseph
J
T
1
1K
Sabre 23
S
S
2
594
Dark Lurker
J
1
308
M
