Technical Cruise Control to a 4x4TA
Guildford
As I mentioned the other week, I have now had my cruise control fitted and I can report that it is utterly fabulous. It is the Gold Cruise GC90 with the GC4 stalk that incorporates 2 preset speeds (user configurable). It was fitted by a firm in Birmingham called Conrad-Anderson, who have to be the most customer friendly bunch of folks I've ever had the pleasure of meeting. http://www.conrad-anderson.co.uk/products/view/cc172055253)
The technical chap (Andy) talked to me about where to place the stalk, what he had to do and how he planned to do it. The stalk looks OEM as far as I am concerned and you'd not know that it wasn't a Fiat option from the factory. I has all the usual features - On, Set, Cancel, Resume - plus the 2 presents that I have configured for 72mph and 52mph (true GPS), so I have easy access to these speeds as required.
It is off by default and needs to be switched on each journey - a push away. Speed is set with a push Up, cancelled with a Pull and resumed with a push Down. The presets are on a small rocker switch on the end of the control stalk.
I drove up to Birmingham late at night and found that even with careful concentration it was easy for the speed to fluctuate quite a bit. I put this down to small engine, small turbo and at 80mph indicated, quite a bit of boost I suspect. Lift off a little to control any increase in speed and boost drops off more than expected, resulting in dropping off of more speed than I expected. So back on the throttle a little until I'm back to where I want to be. And repeat a mile or so later....
.... driving back however on Cruise and the speed is absolutely stuck rigid at whatever speed I set. Really relaxing and in my 260 motorway miles so far, I reckon about 10% better on fuel as a result. I came back at a true 75mph or thereabouts and saw 45mph average (only 8000 miles on the engine, so still 'running in'!), which is a good 4 or 5mpg more than I got on the way there.
But I didn't buy it to save fuel, I just wanted the relaxed comfort that CC brings when the conditions are right. Even when there's more traffic around, I reckon the planning process you go through makes you almost more alert and aware of vehicle movements and relative speeds than when not using CC. Either way, this was the only key thing missing from my post-Audi S4 life and now my Panda is complete!
The kit can be fitted yourself and although it needs some CANBUS 'learning' for the GC90 control box, I believe this can in fact be done by the home fitter, given the information from Conrad-Anderson. Best speak to them first about that though, as all I did was sit in their waiting room, using their WiFi, drinking their tea and getting on with work seamlessly, which was just so easy. (y)
Now that looks a bit of alright.
Thats the only option I was expecting to find on the new Panda that was absent. Think i might be giving them a call at some point.
Great post, R1NGA. Lack of CC is my major beef with the Cross (that and those useless cup-holders). I got so wedded to using CC on my old DS3, which had fabulously smooth and easily-controllable CC, that I tended to use it as a hand-throttle to accelerate up and down the gears. Worked a treat, and spared me much pain in my arthritic right ankle.
Does the system you've fitted allow you to adjust your speed easily via the + and - controls? And is it easily adjustable by feel while holding the steering wheel? (I hate the ones that are mounted on the front of the steering wheel - it's far safer to work the controls by feel.)
And the $64000 question - how much did it cost, all in? (Edit - just clicked on the link - £535 fitted - gulp!!!)
Great post, R1NGA. Lack of CC is my major beef with the Cross. I got so wedded to using it on my old DS3, which had fabulously smooth and easily-controllable CC, that I could almost use it as a hand throttle to accelerate up and down the gears!
Does the system you've fitted allow you to adjust your speed easily via the + and - controls? And is it easily adjustable by feel while holding the steering wheel? (I hate the ones that are mounted on the front of the steering wheel - it's far safer to work the controls by feel)
Yes and Yes. Close enough to control with fingertips whilse still holding the wheel. Increase and Descrease in 1kmh increments with brief push up or down, or change speed by 10-15kmh either way with a l_o_n_g push up or down. Simples!
Great. Presumably all you miss is the digital read-out of the speed that you've programmed in, hence the advantage of having the presets.
This sounds the Bee's leg joints; wonder why Fiat don't offer it? I think the TA in particular responds best to a steady throttle and CC would certainly keep that under control, got to be good for economy.
Zacly. You learn quickly Skywalker..... :)
I do appreciate that £500 is a bit keen, but fit it yourself and with a stock stalk, it's £385. Still pricey, but if you pay peanuts etc....... To a certain extent I'm feeling a little flush I guess, as my (when new) £49k Audi has been entirely replaced by the awesome and hugely cheaper little Panda. I now have my perfect day-to-day car!
Does anyone know if this service is available in the London/Surrey area?
