Technical  Crap Demisters - Part 2!
on the A684
My fan has died.
The electronic parts seem fine, turning to 'max defrost' turns on all the lights it should. I'm guessing defunct relay or if I'm unlucky a dead motor.
Anyone know the whereabouts of the relay?
p.s. it was frickin freezing this morning brrrr
iirc the relay was not on the fusebox, instead it was on the motor assembly, above it, and slightly to the right when sat in a front seat. there were 2 relays, one to control slow speed, and one to control other speeds, this is why a relay failure usually results in slow speed working only, or only slow speed not working.
then it does not sound like a relay problem mate, i'd check power and earth wiring, and fuse. the lights that come on use seperate wiring to the motor itself, the 2 circuits are seperated by a relay so a fault in one would not mean a fault in the other. that means the lights can come on even if the motor gets no power.
