Technical  Crankshaft Position Sensor
rkl2017
Hello to everybody,
does anyone know what voltage should be on the crank sensor between the terminals?
Fiat stilo 1.6 16v, occasionally does not start and I measured 2V what go from ECU to sensor but I think it's little
Thank you
Is the crank sensor the one visible under the crank pulley right next to the wheel arch? Where did you measure it? I'm half remembering a connector about head gasket level on the front of the engine?
