Technical  Could a turbo be fitted?
FiatUnknown
England
Hi All,
I have a Fiat Tipo Easy 95 1.4L Hatchback (2018),
I did not pay much attention to the fact that the higher priced Tipo's i saw when car browsing actually had turbo's and much more power than the one that i decided to buy as i was just looking for a newer car that looks half-decent, however now that the new car phase has worn off i find the car to be really slow on acceleration.
Since the Tipo's with turbos are basically the same car just give or take a bigger engine slightly and including a turbo i was wondering if its actually feasible to install a turbo onto the car that i have or if its more or less impossible, given that the Tipo's with turbos look identical i don't know if that is the case for the mechanical parts inside.
Thanks!
- Currently getting into the 3-4K rev range just to not slow everybody else down :')
Model
Easy 95
Year
2018
Mileage
74014
The simple answer is.......it would cost a fortune, it is not as simple as you think.
If you want one with a turbo buy one with a turbo.
