Technical P2563 on 1.3 mjet tipo
MohsenTheHedgehog
Turkey
Hello guys. I have recently found out this forum and its really helpful.
Recently I have started to see an engine code on my tipo (1.3mjet,2017). The code only comes when the engine is cold. (P2563) and the car loses power. I delete it via obd and the issue gets solved right away, until the next cold start. I have replaced the turbo, intercooler, turbo solenoid, and got the whole engine repaired including injectors etc. I have stage1 with dpf and egr off. Finally I recently checked if there were any leaks via smoke test to no avail. Any help would be much appreciated. Thanks in advance 🥹
Model
Tipo
Year
2017
Mileage
214000
First of all, thank you for your responses. I’ve found out that some of the vehicles produced in my country in this model year (2017) came with VGT turbos, while others were equipped with regular turbos. So I can’t say anything for sure. There seems to be a small electronic sensor on the turbo, and it hasn’t been replaced yet. Would you recommend replacing it?
That's what I said, it's a variable vane turbo, that sensor is the boost control position sensor mentioned in my previous post
Definitely recommended
The one I’ve changed looks like this. Are there any other sensors related to the issue?
Better for you to search in your country for 'Tipo boost control position sensor' maybe in ebay where you can put your reg number in to filter the parts for your particular car..
If Eper went up to 2017 cars I'd give you a part number , but it doesn't
