Hi guys,
Bit of a strange one. As you know, the coolant is in a sealed unit and shouldn't escape however after months of knowing my coolant has remained at the MAX point, I decided today to check it, only to find it was about 2cm below MAX. Not a big difference, I know, but still enough to stun me.
Just to add, the vehicle was parked on a level, not facing up/down hill throwing out the level. There was no visible ''pink'' staining on or around the coolant piping. The cabin windscreen doesn't steam up and the cabin doesn't smell sweet (normally a sign of a leaking heater matrix). The radiator appears to be very clean and the cambelt area is dry (no sign of the water pump leaking). The water pump is only 1 year old and I did suffer with it leaking just after it was fitted, but now it's sorted.
My hope is that the cap might not have been on properly, I only turn it clock wise until I hear the click, that I believe is normal.
Any help is appreciated as always.
Regards,
Matt.
Regards,
Matt.
