Malin Dixon
- Joined
- Jun 24, 2006
- Messages
- 69
- Points
- 10
Fivehundred said:How can air get in by having all the plugs out? The valves are still operating so there isn't suddenly some way for a cylinder to suck air in through another cylinder's spark plug hole!
When the engine is turning, and all the plugs are out, air can enter down any hole that hasn't got a compression guage connected to it.
The 3 other cylinders will suck air down their plug holes rather than from the manifold if the throttle is closed. There certainly won't be an significant manifold vacuum.
There will be a short period when the cylinder being tested is sucking air from a closed manifold and all the other inlet valves are closed. However, the inlet valve actually closes a long time after BDC (bottom dead center) so by the time the inlet valve closes, one of the other ones has been open for some time, letting air into the manifold.
Also, the manifold is quite large compared to a single cylinder, so there wouldn't be much drop in pressure by sucking one cylinder volume out of the manifold which starts off at atmospheric pressure.
If you don't believe me, jam the throttle open, but I'll be very surprised if it makes any change to the reading. I did a compression test and correctly diagnosed a dead exhaust valve and I didn't open the throttle.
Of course, all of this relies on an engine with 4 or more cylinders and only one manifold for the lot. I know some engines have one throttle per cylinder and for them you have to have the throttles open. God knows how you do a compression test on a 2007 Mini. The'll have no throttle and just vary the valve timing to control the engine.
