com port confusion
com port confusion
Essex/Suffolk border
i have some diagnostic software on my laptop that connects via a serial port.
the hardware came with a usb to serial adapter.
i have installed the driver for it but device manager says its now com18. but my diag software will only let me select com ports from 1 to 8 :bang:
how do i fix that delete and re install driver and hope it get assigned a different port number?
thanks
Hopefully what you've found will fix the issue.
I no longer have a working XP machine, but Win7 (best Windows ever in my experience) allows this:
Plug the ELM in.
Open Device Manager. Should see an option of 'Ports (COM & LPT)' Expand this to see your ELM.
Right-click your ELM, choose 'Settings', then 'Port Settings' and 'Advanced'.
The current Com port should be in a box with a drop arrow, which should give a list of ports to choose from.
that was it thanks for the help. i have no idea how i missed the advance tab before. got it all working and got into ecu to access fault codes but still none the wiser
Trip Code: 1502 105 occurrences Solenoid Brake Trip
Trip Code: 4401 20 occurrences Internal Control System Trip
Trip Code: 0E08 1 occurrences Throttle Trip
Trip Code: 3D02 5 occurrences Motor Wiring Trip
Trip Code: 3B01 45 occurrences Motor Disconnected
Trip Code: 0A00 14 occurrences Control System in Sleep Mode
Trip Code: 2F01 10 occurrences Throttle Displaced at Power-up
Trip Code: 1E08 188 occurrences Off-Board Charger Connected
the ones to worry about are in bold, ive bench tested motor and that seems fine, i will whip electric brake off and give it a test
