General clutch..
General clutch..
mattstoke
I have a multipla on a 54 plate, recently when on a bank and i pull off i can smell the clutch, its not slipping or anything yet but also judders frequently on flat pulloffs, but i am starting to think the clutch could be on the way out, firstly is there anything i can look out for and test, secondly i can get cheap parts through a friend but am not mechanically minded so couldnt do it myself, does anyone know anyone in stoke-on-trent or near that could fit it for me as cheap as possible, cause running a house with 4 kids doesnt leave me much spare cash also i am really worried at seeing prices of £700-£800 for changes..
It depends on whether you have a petrol or diesel model. A 1.6 petrol Multipla is a reasonbly straightforward job, budget around £300 supply and fit. If they tell you it's a seven and a half hour job etc. walk away because they either don't know what they're talking about or think you don't know what they're talking about! Diesel is a different matter as youi have a dual-mass flywheel which is best to change as well (may even be the main problem) which will double the price. I would'nt recomend you supply your own parts, it provides an easy get-out for the fitter if things are not right.
Thank god its a petrol :) also thanks for your info much appreciated, shame i didn't live closer to you :D
Anyone local to me fancies making some £ or know of a mechanic who would fancy doing it?
cheers
have you checked the fluid level?
im in derby mate, im an apprentice mechanic, and do loads of work from home on cars if you could get it to me mate i could do it for you cheap enough
I get some clutch judder when setting off and am thinking of changing the flywheel to a non dual-mass effort.
Can anyone tell me model/make/year of other cars that have a flywheel that will fit my 2001 105 jtd so I can get down the scrapyard and find one???
Thanks, st1vo
Before you start messing with flywheels, make sure your crankshaft pulley is OK. It's a metal-rubber-metal sandwich and after I had mine replaced all the judder I'd been whingeing about disappeared
