hi i have a 1.6l fiat tipo and the clutch pedal is not working at all. i think it could b the clutch cable but i cannot fint out how to change it or even locate it, please can somone help.
check down under the battery. Ontop the gearbox is the clutch slave cylinder if it's hydraulic. These usually fail first in the system. Also check the brake reservoir, if it's hydraulic it will have 3 pipes out the bottom of it.
