I have a 1.2 Stilo which seems to be having clutch problems. At first I had problems engaging reverse which seemed to crunch everytime I tried, It would go in but crunching. The other gears went in but seemed tougher than usual.
With the other gears becoming harder to engage I decided to take a look at the slave cylinder having read some of the threads in the forum. The old slave cylinder was lookin a little worn and havinf removed it I found the barrel inside just came right out spring and all. I assumed this was broken although no sign of fluid leaks. I replaced the cylinder and bled the system at the beed nipple on the cylinder using a bleed kit. The pressure seems to be back up now and the cylinder is moving however I am not sure if it is moving the fork enough as I believe there is a good centimeter of movement left on the cylinder.
Does anyone think I need to start looking at the Master Cylinder for lack of pressure? Or is my clutch looking like it my be past it? 67000 miles?
I think i could bear the costs for the master cylinder, the cost of a new clutch however scares me.
