Technical clutch problem
ms24
hi i have a 2.4 stilo and my clutch peadel has stuck to the floor while i was changing gears to use it again i had to pull it up with my hand but once i had done this it worked fine again when i got home i checked the fluid level and found it half way down it was full.does anyone have any ideas what could be wrong.
If you've lost that much hyd fluid then you probably have a leaking slave cylinder (highly likely) or a leak on your brakes
