As the title says my the clutch pedal on my Panda twinair 4x4 has started to stick on the floor. It then will not change gear. If I pull up the pedal the clutch starts working but the problem comes back again soon.
I am not loosing any fluid (level in the reservoir is where it should be and there are no signs of fluid on the floor where it is parked).
I am suspecting master or slave cylinder. Any suggestions on how to identify which is more likely and are there any guides on how to change them?
Any other suggestions would be appreciated.
Chris
Chris
