Punto (Mk1) clutch master cylinder
charlie12363
Hi all can u tell me where i can get a clutch master cylinder for a fiat punto 55 1.1 1997 can not get one any where there was one on ebay for £110 i thought a bit to expensive any one any ideas where i can get one from please
got a clutch master cylinder from eurocarparts £98 reduced from £175 no other place could beat that, once fitted would i need to bleed every thing clutch and brakes, looks like i may have to. not sure about bleeding brakes any help would be much appreciated many thanks:confused:
bleeding brakes is just time consuming, ensure all 4 bleed nipples work 1st;)
give them a good soak for hours before moving with a good fitting socket,
Charlie
The old one was leaking i realised that when i had a puddle of brake fluid by my feet. just put the new one on the pipe at the top should just push on, cant do it is there an easier way quite difficult to get to:bang:
