- Joined
- Aug 19, 2010
- Messages
- 1,616
- Points
- 456
Hi.
This is a little issue I had on my Panda not long after I got it and it's back.
I noticed on quick gear changes upward at around 3-4000 rpm there is a roughness sound transmitted into the cabin when depressing the clutch and giving a little throttle just as the clutch bites. Ease off before pressing the the clutch and there is no noise whatsoever.
At the time I put blue tack between the coils on the pipe to the slave and this made a huge difference, the blue tack has now gone and the noise has retuned.
I'd like a more permanent fix and reading through various threads the MJ versions are prone to this and there are some that have had it on the 1.2 & TA. Fiat fit an exorbitantly priced damper for a total cure but the old Rover 75 had one that looks the same for under £40.
See here https://www.ebay.co.uk/itm/ROVER-75-MG-ZT-ZTT-CDT-CDTI-CLUTCH-DAMPER-KIT-STD000010-/333749791290
Does anyone have one of these dampers fitted and is it possible it can be confirmed it looks the same.
Many thanks.
Many thanks.
