Hi guys,
A few months back i had my clutch cable snap on me at the pedal side of the cable.
so i replaced the cable with the correct part for my model.
Now, it's gone and snapped again, yet this time, it's the white housing that fits into the bodywork behind the clutch pedal!
The car started to get a little hard to turn over.. then five minutes down the road, it just shattered (the white fitting) and my clutch went. Pulled over to the side of the road, and when i went to turn the engine over again, i had the same problem that i had with turning it over.. this was fixed once moving the clutch arm into a different position.
Is this a frequent problem with pandas... i see a lot of posts on here regarding the clutch cable and some snapping every other month. my clutch did start to feel heavy, making the odd crunching noise now and then before it went.
i'm thinking of possibly buying one of the newer clutch cables with the metal fixture instead of the white plastic rubbish and trying to fit that as well.
any advice, info or past experience of this would be of great help.
thanks in advance
thanks in advance
