Raph406
i'm having some trouble trying to bleed the clutch. the rubber clutch hydraulic line split and started leaking fluid. i took it off and bought a new one. I also replaced the slave cylinder about a month ago. I topped off the reservoir and started pumping. then when i was cracking the bleed screw on the slave. it kept on pumping out clear brake fluid. After doing this for awhile with no air bubbles coming out and no pressure on the clutch pedal. i then took off the clutch line and filled it with fluid and reattached it. i then tried bleeding it again. Still alot of fluid comes out but no air bubbles and no pressure on the clutch. it still stays on the floor
Any help appreciated Thanks
