Have you tried 8 x 1.25mm? Afaik, this is what was used on all the X1-9's and most other older Fiats.
Maybe remove one of the bleed screws to check the size?
If you clamp the brake hose, you can remove one of the bleed screws without losing fluid or having to bleed the brakes afterwards.
Al.
