Technical Cinquecento switch illumination
babbo_umbro
Established member
Devon and Umbria
There are several threads mentioning modifying the backlighting on Cinqucento dash, and one or two that mention the problem I have - all the backlighting that depends on the Yellow/black (G/N in wiring diagram) wire coming off fuse 11 are dead - heater controls, window switches, clock backlight, etc. Other services off that fuse are OK. Trying to follow the wiring is like looking for a particular strand in a plate of spaghetti. Any advice? Is there a single connector somewhere that takes the feed off to the various lights?
Start by taking one of the lights and check that you haven't got power to it. It could be an earth problem, if everything else is working.
