Technical Cinquecento 899cc starting issue's
Scott89
Aberdeenshire
Hi everyone,
Having issues with my 899cc not starting and hoping you could help please.
I'll start at the beginning. Over a year ago I bought the cinquecento as a project, previous owner hadn't tried starting it in a while. Once it arrived with me it turned over no problem but didn't fire up, so I took that as maybe needing fresh fuel plugs etc. So that was changed but still not starting. Then looked further into it and notice I wasn't getting spark or fuel. Crank sensor would be a good shout at this point but again new sensor made no difference.
At this point I wasn't getting to the car much with other commitments until just recently. So back to it after trying some other tests( to the best of my abilities ), simple things like checking clean earth points, fuses good, relays fine. As I was delving deeper I started to worry it was maybe an immobiliser issue and I only had one blue key. So to cover all bases I purchased an ecu set with 2 blue keys and 1 red/brown key, immobiliser, ignition barrel etc. I also decided to just cover things being this deep into it and get a new fuel pump and some new relays for that side of things.
So this morning I installed all those parts. Whilst replacing the fuel pump I gave the tank a syphon and clean of any crap that was at the bottom of the tank. Replaced with some fresh fuel, plugged everything back in and still cranks over but not starting. Checked the plugs which were bone dry and not sparking.
In total all the parts I've replaced so far have been.
Plugs,leads,coils, air filter, fuel filter, crank sensor, fuel pump, fuel pump relay, ecu, ignition barrel, immobiliser, battery and fresh fuel.
Am I missing something so stupid as to why it will crank over perfectly but not fire up.
I don't want to give up on this car but I'm struggling with where to go with it at this point.
Appreciate anything you guys can offer.
Model
Cinquecento 899cc sx
1998
Mileage
79000
Does the orange key code light go out on the dash after you turn the ignition on or does the light stay permanently lit, it's meant to go out after a couple of seconds of turning on the ignition
I can confirm that it does go off after a second of putting the ignition on.
I'm wondering if it could perhaps be either a faulty solenoid on the starter motor or the cheaper option which happened on my own car a while ago it was having difficulty starting it turned out to be the coolant temperature sensor at fault (on top of thermostat housing) as this sends signal to the ECU telling it which air & fuel mixture to do etc so it was over fuelling preventing it from starting, the part was just under £8 delivered, changed in minutes & started up first go. The part number for the 899 is 46477022 it's the same on both Cinquecento's & Seicento's
