redVXcoupe
- Joined
- Feb 20, 2008
- Messages
- 24
- Points
- 3
Good evening and thanks for answers.
Hf turbo, tested with the other map sensor (from P 75 Mpi), no difference.
Next thing is swapping the Ecu's...like you have.
Did you do any thing with wire "26"?
Funny thing...disconnected the lambda, no difference at start up. Did not check warm engine. Disconnected the temp sensor and the engine still runs the same way as before but the injector light is on. Connected the sensor, engine runs the same way. Connected a separate sensor, still the same. Heated the sensor and the engine dies after a while.
Is it a chip for this Ecu Mpi like the Spi (gazzaman2k maybe ) so I can avoid the extra coded key. I have a plan hiding the coded Punto key somewhere under the dash because I will keep the original key.
-Tore
-Tore
