Technical  chipped key
rsgranduca
my scudo 2001 jtd has a fault code p1517 anti theft code ,where do i start with this fault thanks matt:)
its had anew fuel pum€p and yhe ecu has been refurbed but it was running after these parts where fitted ,it also has a toad alarm fitted could it be that, my red light at the top of dash dosnt come on at any time .it just turns over but doesnt fire cheers matt:)
what would cause the immobiliser light at the top of dash not to come on?:)
tried every fuse not 100% if the security system has a relay ,mayby if i got the key recoded the light would work ,the fault code p1517 ( anti theft device )is the fault showing any ideas:)
electrio been out started with some basics there were no noise from pump in tank so he put a feed to it it and it works ,he removed big brown relay and refitted it so the pump now comes on with ignition, the only thing is it just makes a dull thump noise as if theres no diesal in tank it doesnt pump as such,also what is the purple relay in fuse box under bonnet for.
all this and i still have an immobiliser issue one thing at a time any info would be great thanks matt:cry:e
