Hi again
I've noticed that the coolant in my 1.4 6speed is looking a bit brown and dirty so am going to do a system flush and change. I've read so many different ways of doing it. So I just need the simplest way. Do you have to drain then fill then run engine to remove air? Or should you just let it settle and work itself out? Also where is the best place to drain from and what's the best way to flush it through? I've read many that say refill with water and run engine to circulate but am just a bit muddled about the best way to do it. A step by step would be very handy indeed.
Any help would be much appreciated.
