Technical  Car wont start
My 1.9JTD Bug has stood unused for a month and now wont start.
When I try, all the dash lights go off and there is a click but no motion on the starter. When I checked the voltage on the battery it was 11.9V which should be enough. I had a new battery so I fitted it but no difference. After a couple of days of trying I managed to push the car back on the drive and got it the right way round to tow it.
Now when I try the ignition all the dash lights blink continuously and there is a clicking noise from behind the battery. I was working on the brakes before and nothing relates to this. I will try jump leads between the batteries next but would welcome suggestions of where to look
I know the lead from the battery divides and presumably feeds various relays but the main lead to the starter is direct with the ignition controlling the starter solenoid
I had a couple of episodes where the battery drained overnight. I had a spare battery which registered about that 11.9 value and I just got a click from the starter. It took 12 or more hours on charge to make it work.
Disconnect and charge it for a day. The voltage at the end of the charging process goes to 15v or so.
I have them on charge tonight so will try again in the morning
One further thought, i had trouble back in July when the battery was off all day and the car wouldn't start again, It turned out to be relays and/or fuses in the black box by the battery. When lifting the battery in and out it's possible or even likely that your arm will move the box about and unseat the bits inside. Pressing everything back firmly seemed to make things work again.
Thanks Wiltshire. When the dash lights kept twitching and a relay was clicking I knew it just had to be an electrical connection, especially when the fuel tank read empty and I knew it was full! I removed the battery again and rechecked all the connections and opened all the fuse boxes and twiddled them especially the one for the ignition and on reconnecting the most recent problem was gone. Unfortunately I still have the problem that the motor doesn't turn over.... I guess the non-use for a month has either left the solenoid stuck or the motor. I can't see why the connection from the battery should be affected by non-use.
Anyone know what I can try without getting under the car?
Tried with the jump leads but no difference: just the same click and all the lights on dash go off. Also rocked the car in gear. Cant see on eLearn a fuse specifically for the starter.: anyone know which it is? Have ordered a new starter motor for £39.99 off ebay but may find that isn't the problem... Now to remove the old one. I remember doing this when I wrote an article on renewing the clutch and remember the problem with the top bolt. Will read the article again to see how I did it! I have jacked the car up and supported it with axle stands and wood.
Was getting a drip in the eye so poked in the nearly blocked drainage pipe and got a litre more in the eye!!! Hope it is warm and dry tomorrow
Hit the starter motor and solenoid a few slaps whilst having someone toggling the ignition... could well be starter motor brushes just not quite contacting the commutator in the starter motor and they need a little persuasion. If you have a handle of a pick axe or something of similar mass that you can get it there give it a few belts.. I’ve a feeling that’s your problem.
Marty.
No progress
When the problem first occurred I wondered if having stood unused for a month or more there had been a cylinder head leak which stopped the engine turning. After towing the car in 5th gear with no problem I ruled that out.
I checked the earths and all were fine.
I then suspected the starter motor had seized as it connected directly to the good battery. I haven’t yet checked there is a supply to the solenoid.
Having found a very cheap new starter motor I installed it: no easier the second time around but it will be next time!
As I feared, it made no difference. I still get the same noise and no rotation of the engine.
Ran FIATecuScan and have attached the error report.
After clearing the errors all three reappear.
I now suspect that the first error reported as FATAL may mean that the ecu aborts the start. The other two may be consequential. I have had the flashing coil light running for 20 seconds or so every time I start for over a year but as it has always started so I assumed this meant they weren’t essential. Perhaps if all 4 go the error really is FATAL.
Could someone else who has the coil light running check if FIATecuScan registers the fault as FATAL?
Advice welcome
  • FiatErrors.pdf
I have since got under the car again to check voltages. The supply to the main terminal on the starter is fine so the main positive cable from the battery to the starter and alternator is sound.
There is no supply to the solenoid when the key is turned. So that narrows the field a bit...
The fact that the instrument display is illuminated when the ignition is turned on suggests that the main ignition supply from the MaxiFuseBox B5 is OK. There is a wire from the ignition switch to the starter solenoid through junction D4. Does anyone know where D4 is and which wire this is. A picture of the ignition switch connects would also be helpful.
Possibly you could check for continuity between the wire that connects to starter solenoid and the ignition switch.
Sorry I don't have answers for your specific questions.
Good luck.
Oh just remembered there is a black plastic box under bonnet to right of battery containing fuses and relays. Take lid off and give the relays a tap.
Maybe you have checked this but I had the same symptoms, after much head scratching and messing about, it was corrosion micro cracks on the positive terminal. It looked fine, smelled fine but wasn't making sufficient contact with the battery terminal. I changed the connector for a big brass bastard and it was fine.
Hope this helps
Mik
Re: Car wont start: problem found
Thanks to everyone for suggestions.
I think I have solved the problem
I have checked the wiring using FIAT eLearn: part codes are provided. The supply from the IGN 30A Maxi fuse, B5, to the ignition switch, H1, seemed fine: this is a Red/Black (RN) cable to the centre pin (30) on the 3x1 connector, H001A, on the back of the ignition switch. A Brown/Black (MN) cable goes from pin (50) on the same 3x1 connector to pin G on a 7 pin connector, D004B, (which I have yet to find) and then on as a Brown/Black cable to the starter motor solenoid. (The third pin is for ABS while the other connector on the back of the ignition switch, H001B, is for other things (clearer when you zoom in E5010 on eLearn)).
So the Red/Black cable is the feed to the ignition switch (see 5520A12) and the Brown/Black cable is the feed to the starter motor solenoid, through connector block D004B. When I checked at pin 50 on the ignition switch I got a fluctuating voltage suggesting a poor supply or faulty switch.
(Note: Perhaps someone could explain how with the supply to the actual starter motor (30) coming directly from the battery and earthing through the casing the motor doesn’t run continuously? Is there is a relay inside the solenoid so that current only flows after the pinion has engaged with the flywheel ring gear?)
If I turn the key all the way I could hear a quiet click but not from the starter motor or starter solenoid, probably just a relay behind the dashboard. There is no ‘attempt’ to turn the engine but there is a slight current drain which takes the battery down from say 11.9V to settle at 11.7V. The battery is now re-charged to 12.5V.
This suggested to me that there were 6 possible conditions: the first two mechanical and the other four the result of an open-circuit.
1) My first thought had been that the starter motor might be seized because of all the rain since Christmas, though everything had been fine before I started doing the handbrake. Picked up a new one cheaply and fitted it – no difference.
2) My second pessimistic thought was that having stood unused for 4-6 weeks while I did the handbrake may have led to one or more cylinders containing coolant water as a result of an unsuspected cylinder head failure. Again no symptoms of this were noticed before laying the bug up. I thought I had ruled that out by foolishly towing the car about 5 yards in 5th gear (foolishly because I could have made the timing belt jump or break and possibly bent one or more valves or conrods!). I have since easily turned the engine 3 complete turns counter-clockwise by using my torque wrench on the 19mm socket on the bolt holding the auxiliary belt pulley so have ruled out this possibility. Turning in the clockwise direction was not possible but I don’t know why.
3) I ran FIATecuScan which returned 3 errors which all reappeared after clearing. The first was glowplugs which said FATAL ERROR. I wondered if all 4 had failed meant the ecu aborted the start up. Knowing that it is generally agreed that the Multipla doesn’t need glowplugs to start when temperature is above –10 I discounted this.
4) The ignition switch might be faulty. I ruled this out by checking for continuity over pins 50 and 30 after disconnecting the cable connector H001A and fully turning the key.
5) Lack of continuity between pin 50 on the ignition switch and pin 50 on the starter solenoid.
My multimeter wouldn’t reach so I disconnected the solenoid cable and ran a jump lead to the disconnected Brown/Black cable by the ignition switch. Continuity OK
6) The connection at the 30A blade maxifuse at B5 (by the battery) might be suspect so allowing an adequate feed to the instrument display but not the higher current needed for the solenoid. The fact that I had an episode of constant relay clicking and incomplete testing when just turning the ignition on would support this especially when it was ‘cured’ by twiddling the ignition maxi fuse. I first dismantled the B5 maxifuse casing and checked the bolt below the 4 fuses was fully tightened: it was. The maxifuse feeds Pin 30 at the ignition switch which is the Common to all the connections inside the switch including the pin 50 to the starter solenoid. Using the blade of a screwdriver I ‘crimped’ the female fuse holder ends to ensure tighter contact with the blades of the fuse.
After all this I did manage to get the engine to turn a little on the key but only like you get when the battery is almost flat. Same result when a second good battery was attached with jump leads.
Putting my thinking cap on, the fact that I could only turn the engine by ‘hand’ anti-clockwise but not clockwise (thinks there is a freewheel pulley on the alternator…), the absence of any rotation on the key, the current drain which could only come from starter motor trying to work led me to another possible mechanical condition that the alternator had seized. Removing the auxiliary belt confirmed this as the engine started immediately.
Now to find a cheap new Denso Dan501 105A alternator…
Have started removing the alternator. Got the lower bolt out. Cant get enough purchase on the upper bolt and even the 10mm bottom bolt on the dipstick is inaccessible...... Have disconnected the front exhaust
It is so cold:(
The car is well jacked up and I should be able to get the alternator off and removed. Someone mentioned there is a spacer on the top bolt but nothing is shown on eLearn. I haven't got to it yet but where does it go when I reassemble?
