Hi everyone,
I have an automatic 1.9 jtd 150hp.
It happened once before but started becoming more often after I changed the engine oil and filters two weeks ago. Basically, once in a while, the car stalls when I am slowing down to stop, engine(red) and battery lights come on and the display reads the message that low engine oil pressure. Once I turn off and re-start the car again, everything goes back to normal and it runs normally.
Ecu reports no errors. I checked the oil level and it is at Max. Other values the ECU scan has shown are following: Battery voltage (14,056 V), oil degradation level (73.9%), distance to the next oil change (37k km), differential pressure sensor (8mbar), particle filter status (normal clogging), particulate filter clogging (106%), pressure regulator opening (mprop)(34,830), engine oil pressure (normal), boost pressure (1155mbar), EGR valve opening (3.998%), EGR control (OFF).
Do you think it is an oil-related issue? or something else stalls the car and since the car is stalled it warns about low oil pressure? What do you, in general, think that it could be?
